Set EEPROM size code
2,413 次查看
hayouniaymen
I'm using the driver example of flexnvm_eeprom in SDk2.
and I need to change the size code of the EEPROM from 32bytes (mentioned in the demo : #define EEPROM_DATA_SET_SIZE_CODE (0x39U) )  to 3K.
How can I poursuit to change the size please?
2,309 次查看
kerryzhou
Hi hayouni,
  Please tell me what the kinetis chip you are using? Please tell me the chip part number.
  I will help you to check it.
Actually, you can check that chip's reference manual, flash chapter, to check the partition content.
Kerry
2,309 次查看
kerryzhou
Hi hayouni,
Kerry
2,309 次查看
hayouniaymen
Thank's Kerry,
I checked the reference manual and i m able now to change the data size code of the EEPROM partition.
