Serial Wire Debug(SWD)
Arun5
Hello all
Here am using FRDM-KW36, i need to use SWD for Programming(initial Bootloader programming), please suggest me that whether i required any debugger or not  if any please suggest the part number and related details of debugger. also am new to SWD please provide with suitable hardware schematic diagram to connect my board and programming for SWD programming
nxf56274
The frdm-kw36 has debugger. You don't need a external debugger unless you need to update the debugger firmware.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
