Serial Port with the FRDM K66F
1,629 次查看
PJay
I am following the steps documented in "Get Started with the FRDM-K66F" (https://www.nxp.com/document/guide/get-started-with-the-frdm-k66f:NGS-FRDM-K66F) to get serial access to a Windows 10 Tera Term COM port and the hello_world sample being debugged by MCUXpresso.
I have followed the 2.4 PC Configuration described in the Getting Started document. I downloaded and installed the driver.
With the K66F powered up, Device Manager displays under Ports (COM & LPT)  JLink CDC UART Port (COM5). I do not see mbed, nor virtial com, nor OpenSDA listed as I have read in many articles.
With Tera Term COM5 connected and configured as documented in the Getting Started document, I debug the hello_world application, and no output nor input is shown on COM5.
My questions are
1. Can serial output to a Window 10 COM port occur when debugging with MCUXpresso?
2. Do I have to update my OpenSDA software to get this work?
3. Is there some configuration required in the hello_world program to allow the serial input and output through the Windows 10 COM port?
Thank you for your time,
PJ
1,620 次查看
danielchen
HI @PJay
Please set UART output for the selected project when you importing it, the default is semihost console output.
1,621 次查看
danielchen
HI @PJay
1,601 次查看
PJay
Thank you very much Daniel.
After receiving your reply, I searched for uart output and found this excellent solution.
https://community.nxp.com/t5/MCUXpresso-IDE/printf-to-UART-Console/m-p/1058262
I wish I had found that earlier.
I tested your solution and the uart_polling example and was successful with input and output from the COM port.
Thanks again,
PJ
