SPI examples?
SPI examples?
3,589 次查看
tomwood
I am looking for sample code to drive the SPI on a K10   I just need a simple implementation, minimal buffering if any.  I will let Processor expert do the setup. I only need to send, not receive.
3,455 次查看
Hello Tom,
You use Processor Expert , when you add SPI component , right click the component,  then select "help on component " ,
in the Typical Usage , you will find simple demo .
Alice
3,456 次查看
Hello Tom,
Alice
3,455 次查看
tomwood
Thanks – I had looked over the CPU internal peripheral but somehow neglected to look under the Logical device drivers. I found lots of stuff that I found from there. Thanks!
