SPI Trasmit and Receive in KEA-128
1,003件の閲覧回数
vigneshbalaji
Senior Contributor I
    I Have written a SPI Transmit and Receive code.I want you people to Verify it and say me on TRK-KEA-128 Board.
I have attached the codes Below.
Original Attachment has been moved to: SPI_slave_KEA_128-(1).zip
Original Attachment has been moved to: SPI_Master_Transmit.zip
ラベル(2)
752件の閲覧回数
kerryzhou
Hi VIGNESH BALAJI,
    This question is the same as your anther post, I have modified your code and test it, also post the test result, picture and wave, please refer to the reply in that post:
Checking SPI Transmit and receive in KEA-128 using TRK-KEA128
Wish it helps you!
Kerry
