SDK errata
SDK errata
2,479件の閲覧回数
YuZH
Hi, I found a comment in the SDK which says there was a errata007993.I want to know what it is and the impactrt on the Mk60FN or Mk60DN.Thanks.
Please see the attached file .
2,467件の閲覧回数
Robin_Shen
Hi YuZH,
As Erich said, you can use Google to search. Or you can search on the NXP official website:
Robin
2,474件の閲覧回数
ErichStyger
Specialist I
Google (usually) is your friend, for example in
https://www.nxp.com/docs/en/errata/KINETIS_K_5N96B.pdf
search for 7993.
I hope this helps,
Erich
