SDHC_LCTL on Kinetis K27
1,587 次查看
masahirokiniwa
Does Kinetis K27 have SDHC_LCTL pin?
In its reference manual P.2041, Kinetis K27 has SDHC_LCTL pin for led control as below.
But I couldn't find it in K27_Pnout.xlsx.
If K27 has it, could you tell me which pin is used for this function?
M.Kiniwa
1,476 次查看
Hui_Ma
The K27 chip doesn't provide the SDHC_LCTL pin for the limited pin resource.
The K27 reference manual chapter61 is for SDHC module IP, the actual K27 chip provided SDHC pin resource please check table 11-45 SDHC Signal Descriptions.
Thank you for the attention.
Mike
1,477 次查看
Hui_Ma
Mike
