RAppID Bootloader rbf file for KEAZN64
2,212 次查看
yongwookwi
Hello.
I should test TEA-KEA64 Board using Rappid bootloader.
Can I get New Changing Uart Port RAppID Bootloader rbf file ?
I know that TEA-KEA64 ( KEAZN64.rbf ) version Uart port was PTD6, PTD7 ( UART2 )
I want to get a New RappID KEAZN64.rbf changed Uart Port PTA2 ,PTA3 ( UART0 )
Can I get a New KEAZN64.rbf files ?
if somebody help me , I am very appreciate for you.
Thank you.
2,182 次查看
Alexis_A
Hello @yongwookwi,
In the following link you can find the modified rbf.
Alexis Andalon
2,166 次查看
yongwookwi
I am very appreciate for your support.
Thank you
2,183 次查看
Alexis_A
Hello @yongwookwi,
Alexis Andalon
