Problems while using TIMERS in mkl25z128vlk4??????
1,977 次查看
akshayhv
i m trying to write a timers code using interrupts but i m not sure of how to generate a delay of my requirements can only one please help me out on thi
regards
Akshay H V
1,725 次查看
Monica
Senior Contributor III
Hello Akshay,
please don't forget to tell us how's it going! Did it work?
Monica.
1,725 次查看
antonioconcio
Hi Akshay,
You can use Processor Expert to generate code, it is very simple. In your case, in order to generate an interrupt every X time, you can only add the "TimerInt_LDD" components and set the Interrupt period (see image below); in addition you can set the source and set if you wish the Timer Auto or Manual Initialization.
Antonio
