Problem with K60
Problem with K60
1,980 次查看
GerasinIvan
Well, i dont know what name i should mark the discussion.
When i download program on MCU (Run on Flash), it downloads ok, but sometimes after pressing "reset" it doesnt work, and RESET LED is slightly On. It lights not so bright when i pressing "reset", And when it lights so, programm doesnt work. Sometimes helps plug-off and on usb cord, but sometimes no. Whats the promlem?
1,790 次查看
adriansc
Maybe watchdog was enable for your project. This causes that reset light become slightly.
Regards.
1,790 次查看
adriansc
It shows the same behavior when you programs it in RAM?
Regards.
1,790 次查看
GerasinIvan
Well, it shows same behavior only after reset ro Power On/Off. So i can't say :smileyhappy:
I make a new project, and this "problem" does not repeat. But i'm still intresting, what was that.
1,791 次查看
adriansc
Regards.
