Problem with K60
2,106件の閲覧回数
GerasinIvan
Fresh Out Contributor
Well, i dont know what name i should mark the discussion.
When i download program on MCU (Run on Flash), it downloads ok, but sometimes after pressing "reset" it doesnt work, and RESET LED is slightly On. It lights not so bright when i pressing "reset", And when it lights so, programm doesnt work. Sometimes helps plug-off and on usb cord, but sometimes no. Whats the promlem?
1,916件の閲覧回数
adriansc
Maybe watchdog was enable for your project. This causes that reset light become slightly.
Regards.
3 返答(返信)
1,916件の閲覧回数
adriansc
It shows the same behavior when you programs it in RAM?
Regards.
1,916件の閲覧回数
GerasinIvan
Well, it shows same behavior only after reset ro Power On/Off. So i can't say :smileyhappy:
I make a new project, and this "problem" does not repeat. But i'm still intresting, what was that.
1,916件の閲覧回数
adriansc
Regards.
