Open drain output pin on KL25Z?
1,900 次查看
markosiponen
How should I do to set a GPIO output pin as open drain?
There seems to be no option for that?
Or should I set the GPIO as input when I want to set the pin high and set the GPIO as low output when I want to set the pin low?
1,507 次查看
Paul_Tian
Hi, Markosiponen
First, KL series has not open drain control register.
Then I think your solution is OK.  One reminder is attention to pull-up resistor value selection.
Best Regards
Paul
1,508 次查看
Paul_Tian
Hi, Markosiponen
Best Regards
Paul
