My K20 chip does not work out
2,542 次查看
songtao8940
hi,I use the K20, when I weld the board found that the chip is locked, according to the Internet after unlocking unlock K60, pin level can vary, but can not communicate, both bus 485 and can not work, I I would like to ask why this is
2,428 次查看
kerryzhou
If this post answers your question, please click the Correct Answer button. Thank you!
Jingjing
2,428 次查看
kerryzhou
    What the solider temperature you are using? From the K20 datasheet, you can get that the solider temperature should below 260°C.
  Now, do you have the Segger Jlink? You can use the JLINK commander to check, whether you can find the ARM cortex M4 core? If the core can't be found, the chip may be damaged by your solider.
Jingjing
2,428 次查看
songtao8940
hi,
    very thanks,that's exactly what I want to know
2,429 次查看
kerryzhou
Jingjing
