Marking code KL03
Marking code KL03
paolo_norrito
I need to understand the marking code about MKL03Z32VFK4,( mark par , lot production and data code).
Phatsakorn
 I need to understand the marking code about MKL03Z16VFK4R ( mark part , lot production and data code).
Alessandro_avl
I wanted understanding if the MCU  MKL03Z32VFK4 is marked as M03T5V.
Best Regards
Alessandro
Sabina_Bruce
Hello Paolo,
The part number sections are described in the datasheet as follows:
Please let me know if you have further questions.
Sabina
paolo_norrito
I need to understand the marking code write on the package and the data code.
Inviato con BlackBerry Work (www.blackberry.com)
Sabina_Bruce
Hi Paolo,
The first  line  of the chip marking will read M03T5V
The second line is confidential so I am not able to provide specifics but it contains the date code.
Sabina
