MKW24D512 modem SPI issue
1,247 次查看
kevindionne
I am currently using the MKW24D512 and I am trying to read multiple bytes (direct mode) from the modem using the SPI1. It works for the first two bytes, but the third and onward are simply the second byte repeated over and over again. Since the connections are internal, I can't probe the SPI lines... Has anyone encountered this issue??
1,127 次查看
mario_castaneda
Hi Kevin,
Could you please share your initialization SPI code?
Best Regards
Mario
