MKL28Z7 GPIO digital filter function
liangliangma
I read from the MKL28Z7 user manual that there is a digital filter function for the digital input pins, but I can not find the list of the pins that has this function. I tried on all the ports, seems the DFER, DFCR, DFWR registers of all the ports are read only. So where I can find more information about this digital filter function?
Tags (2)
Robin_Shen
Hi Liangliang,
Please download the MKL28ZRM, then read the chapter "3.11.1.1 Port control and interrupt summary".
Robin
Robin_Shen
Hi Liangliang,
Robin
liangliangma
So there is no digital glitch filter on MKL28Z7, what a shame. Thanks for your reply anyway.
How about the passive input filter on PTA4 and PTB19, I cannot find specific document anywhere. I guess it is comprised by the pin internal pull up register (20kΩ~50kΩ), and 25pF pin load for normal/low drive pins, right?
Robin_Shen
Hi Liangliang,
You can find analog/passive filter specifications in DataSheet(MKL28Z512VXX7):
Robin
