MKE06 IO input set
MKE06 IO input set
2,363 次查看
lifeng
SDK_2.3.0_MKE06Z128xxx4: fsl_gpio.c
for input setting, set PDDR OK,  not set PIDR, still disable IO input, read IO return 0.
set PDDR and PIDR for input IO
2,208 次查看
Hui_Ma
Thank you for the info.
The latest MCUXpresso SDK for KE06 had fixed this issue.
Please check below GPIO_PinInit() function at <fsl_gpio.c> file:
Mike
2,208 次查看
lifeng
Thank you !
2,208 次查看
lifeng
Thank you !
