Hi ravindra,
Your MKE04Z128 is the customer board, not the NXP official board, right?
If yes, please note these points:
SWD_DAT, pull up 4.7k to 10K resistor.
NMI, pullup 10K resistor
reset_b pin, pull up 4.7k to 10K resistor, and 0.1uf capacitor.
About the debugger, do you have the JLINK on your side? If yes, I suggest you try JLINK, and the JLINK command can help to check whether your board can find the ARM core directly, if you can't find the ARM core, it means your hardware still have issues.
The above is the JLINK connection example.
Please try it on your side.
If you still have questions about it, please kindy let me know.
Kerry
