We are trying to perform sensored commutated motor control of a BLDC motor using the FRDM evaluation board. My company is planning to use the S9KEAZ32AMLH chip for production of the controller for our product.
Is there Simulink embedded coder support for this chip/Eval board ?
Is there any Model based development support for this chip/Eval board ?
Prashant
Hi Prashant1996,
Normally, we don't simulink the MCU, we debug the code in the MCU directly.
So, we don't have Simulink embedded coder support for this chip/Eval board, we highly recommend you use the debugger to run the code in the EVK board directly, that will be more easy and practical.
Thanks a lot for your understanding.
kerry
