MKE04Z IC DEBUG KWIKSTIK SWD
1,419 次查看
alexloban
Dear Kinetis Community,
im very new in embedded system. And have now a first problem.
Im buy me Kinetis MKE04Z8VTG4 chips in TSSOP 16 package and place one on a pcb.
Buy me SWD Cable, Connector adapter to DIP.
And Kwikstik SWD connecter (J8).
All parts are placed.
In Kwikstik manual i have read i can debug via J8 connector all Kinetis IC's.
I connect Kwikstik and MKE04Z, start J-Link flash and try to erase chip. and get error,
can not connect.
HOW I CAN COUNT PINS of SWD connector wich direction  ? FROM LEFT TO RIGHT  ? UP AND DOWN ??
DATASHEET KWIKSTIK DEBUG SWD
DATASHEET MKE04Z  BUT I DONT  SEE A POINT OF PIN COUNTING ON THE CHIP I SEE A ROUND MARK LIKE IMAGE DOWN.
PIN MAPPING
MY CONNECTION.
It was my first experience. And im sure i do something wrong or its no possible do flash or debug with kwikstik.
I have direct cables to the pins without capacitor, resistors.
Can you help me ?
If it no possible to debug, pleas tell me a little bit what i need to flash chip. i will start a project with out dev board :smileyhappy: only PCB.
THANK YOU VERY MUCH !
alex#
1,228 次查看
adamsojecki
Here's the correct numbering of the pins SWD connector on KwikStik.
Good luck,
Adam.
