MKE TOP MARKING EXPLANATION
sanchezf
Dear team,
I would like to know the marking specification ( partnumber, data code and mask version) for the MKE16F512VLH16
FS
sanchezf
Hi Vicente,
Don't worry. I was wrong and I sent to you a non valid marking.
The problem is solved so we can close the case now.
FS
sanchezf
Is it possible to know the meaning for the following marking ?
202002CNWG
201949CNWG
FS
vicentegomez
Can you please send me a picture of the devices
Have a good day.
sanchezf
Hi Vicente,
FS
ErichStyger
Specialist I
Hi @sanchezf ,
see the data sheet https://www.nxp.com/docs/en/data-sheet/KE1xFP100M168SF0.pdf section 7 Part identification. The mask version you should see with the laser marking on the part.
I hope this helps,
Erich
vicentegomez
Adding
Line 1 is the part number
Line 2 is the mask set
Line 3 is an internal coding that includes the date code.
sanchezf
Hi Vicente,
Is it possible to describe the  internal coding that includes the date code ?
FS
vicentegomez
Sorry, that is an internal information and can not be shared
I only can say that normally the numbers are year and week (yyww)
Vicente G
