Looking for PMSM positional servo drive reference design and code examples.
2,487 次查看
davidmccall
Hi I have found this note
Design of a PMSM Servo System Using the 56F8357 Device, Rev. 0 but it is dated 2006.
Is there anything more up to date using Kinetis V series . what I need is help with code for SMSP / BLAC servo code
A devolopment board setup would be good too.  Any suggestion greatly appreciated
830 次查看
Paul_Tian
Hi, David
There is an application notes for your reference. You can find it from link http://cache.freescale.com/files/32bit/doc/app_note/AN4911.pdf?fpsp=1&WT_TYPE=Application%20Notes&WT...
Hope it can help you.
Best Regards
Paul
830 次查看
davidmccall
Thanks Paul,
There are many sensorless ap notes and reference, But for a positional servo system a sensor is required as smooth low speed response is necessary.
Most are about running fans, pumps and appliances such as washing machines.
So I 'm looking for something that is specifically for positional servo applications under motion control.
best regards,
David
