Location of Processor Expert v10.2
da_vinci
Can anyone please help me with the location where I can download processor expert v10.2. On NXP  website I can only find v10.4.
uC = MK10DX256VLQ10 on custom
ErichStyger
Specialist I
In the CPU setttings, change the interrupts to 'one for every' (see https://mcuoneclipse.com/2012/02/20/oh-my-an-interrupt/ ) so you know which interrupt was firing.
I hope this helps,
Erich
ErichStyger
Specialist I
@da_vinci,
is there a specific reason to use the 10.2 instead of the 10.4? I have switched long time ago to 10.4 and did not see and drawbacks compared to 10.2.
I believe if you download the 10.4, you will find the 10.2 in 'previous versions' on the web interface.
Erich
da_vinci
Hello @ErichStyger
I have a .out that was created using v10.2 and when I build the same using v10.4 I am getting significant size difference in the output (v10.4 has increased the size)
Every time I halt the debug session pointer stops at this ISR
So I wanted to see if the problem is in the code or processor expert version
ErichStyger
Specialist I
I hope this helps,
Erich
da_vinci
I'll check this out. Thanks!
nxf77486
Hello @da_vinci ,
I you have previously downloaded the Processor Expert v10.2. You will find this by entering to My NXP on nxp.com on the Software Licensing and Support.  You will find the Software Accounts software that has been downloaded previously. Please let me know if you find this information useful.
da_vinci
Hello @nxf77486 ,
I have not downloaded the Processor Expert before. I am new to NXP microcontrollers and build tools
Can you please point me to location where I can download older versions of Processor Expert specifically v10.2
