Kwikstik Demo Lab for MQX not working weird problem
1,043 次查看
nabeelkhan
I am using K40X256VLQ100, Downloaded the Demo for MQX and trying it running over MQX 3.7 under Code Warrior 10.1 environment. I have successfully Built the kwitstik demo and more over can easily RUN and Debug it over software without error . But still the demo is not showing on the board or have not able to see anything on my SLCD . software is doing debugging and running what ever i want to do. but nothing take place over the board .however I have to connect the J-link while doing debug or Run otherwise it come up with error as it should do. so don't know where i am going wrong Please help me out
标记 (4)
927 次查看
nabeelkhan
i solved it ... The target task was not correctly selected
928 次查看
nabeelkhan
