Kinetis: how USB attachment is detected?
2,819 次查看
huishao2
I have k20d72m based USB host and k20d50m based USB device. I am just wondering how the USB attachment event is triggered on host USB controller? There are two different cases: powering on the host with device plugged in and pluging in the device after host is powered on. What are the differences there?
Reading through some books, it seems like the pulled up D+ from device is the reason for attachment event. But I don't see any pullup on D+ from my USB device design.
Thanks!
Hui
4 回复数
2,443 次查看
Paul_Tian
Hi, Shao Hui
For case owering on the host with device plugged in, MCU will not receive attach interrupt. For case pluging in the device after host is powered on, MCU will receive attach interrupt. This is the difference from MCU side.
Hope this reply can help you. Thanks.
Best Regards
Paul
2,443 次查看
huishao2
Hi Paul
Thanks for reply.
For interrupt case, what is the signal that actually causes the interrupt/event upon attachment?
Hui
2,443 次查看
Paul_Tian
Hi, Hui
Sorry, I cannot find your attachment. Thanks.
Best Regards
Paul
2,443 次查看
huishao2
Hi Zhe Tian
Basically what I want to understand is the difference between booting up host with USB plugged in and plugging in USB after host bootup, in terms of enumeration process.  That would help on my debugging work.
thanks!
Hui
