Kinetis Programmer for beginners
3,343 次查看
pratiekbhadrana
I know a lot of similar questions have been asked about this, please bear with me. I searched the forum as well as on Google and found out a few helpful sites like USBDM. BUT - This is important - But I couldn't find any simple explanation or solution like how one might find for the PICs. (I used to work with PIC MCUs before) What options does one have for a sub $100 programming device for the Kinetis series MCUs? With minimum assembly work for me, unlike some of the DIY projects, which will become a separate project in their own right.
Here's a list of the options that I have seen -
1. Modifying a Freedom board
     Advantages - Cheapest of the lot. Can use KDS or CW
     Disadvantages - Processor lock in (it will allow only that MCU which is on the original board). Also unauthorized.
2.USBDM
     I couldn't make out what the site expected me to do. Buy their stuff? Build my own? and for a beginner it was quite hard to get to know all the acronyms lol !!
I don't expect a free tool for production programming, but at least a reasonably priced one for production of about 10 pcs a month.
PLEASE NOTE - This is a major stumbling block. If unavailable, we might have to consider moving back to something with cheaper tools.
edit - We chose Freescale because it has a very interactive and helpful community compared to some other ARM suppliers. Also the forum is very well designed for beginners.
标记 (3)
2,951 次查看
pratiekbhadrana
OK I sort of answered my own question here. USBDM is the way to go for me. I found a way of converting a Freedom board into a USBDM device and will use the same.
Thanks YONGLI1z anyway !
For the benfit of other newcomers here's the link USBDM: USBDM-FRDM - USBDM Debugger based on Freescale FRDM-xxxx board
also if you open the USBDM main page look in the documentation section for Freedom based boards.
2,952 次查看
pratiekbhadrana
2,951 次查看
Rick_Li
Hi Partiek Bhadranavar,
I would recommend using USB Multilink Universal which is produced by P&E, you can buy it directly from P&E web site.
the below is the link:
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320137
the price is $199, almost the double price of your budget, but it should be the best choice for you!
