Kinetis / Latch input
2,071 次查看
asapuntz
Looking at KE1xF (or S32K14x)
PORTx->PCR[IRQC] allows an input pin to latch edges or levels which can then be read in PORTx->PCR[ISF] PORTx->ISFR. This is very handy to avoid missing transitions while software is busy with other activities.
However, it seems that this will produce in an interrupt (or DMA) if any pin on PORTx is configured to do so.
I've seen other (Cortex-M4) processors where masking of such interrupts is configurable on a per-pin (rather than per-port) basis. Is this level of control not available?
2,026 次查看
asapuntz
would be useful to have PORTx->PCR[IRQC] options which don't produce interrupts or DMA
2,019 次查看
CarlosGarabito
We will consider it for new MCU designs, thank you.
2,027 次查看
CarlosGarabito
Hi @asapuntz , sorry, but no, it is not available
