Kinetis K24 Clock
Kinetis K24 Clock
smathad
Hello all,
I am working on the NXP K24 clock. I see that there are multiple clocks available to choose from. While the reference manual does give some description about the clocks, it is very generic.
I did not find a document explaining me the exact use of each of these clocks.
Can somebody explain to me the use case of each of these clocks? I have listen them below.
  1. MCGIRCLK
  2. MCGFFCLK
  3. Core/System Clocks
  4. Bus clock
  5. FlexBus clock
  6. Flash Clock
  7. MCGPLLCLK/MCGFLLCLK
  8. OSCERCLK
  9. ERCLK32K
  10. LPO
  11. RTC_CLKOUT
Sachin
kerryzhou
Hi Sachin Mathad ,
   Thanks for your interest in the NXP kinetis product, I would like to provide service for you.
   About the use case of each clock, in fact, you can refer to the MK24 reference manual , Chapter 5 Clock Distribution.
   5.4 Clock definitions, this chapter told you each clock usage.
   Table 5-2. Module clocks, told you each module clock situation.
   Please read the MK24 reference manual clock distribution chapter at first.
https://www.nxp.com/webapp/Download?colCode=K24P144M120SF5RM
If you still have questions about it, please kindly let me know.
Kerry
kerryzhou
Hi Sachin Mathad ,
Kerry
smathad
Hi Kerry,
Thank you for your response.
I did find that table helpful.
Can you please let me know the difference between bus interface clock, internal clock and I/o interface clock in that table?
Sachin
kerryzhou
Hi Sachin Mathad,
  You are welcome!
   Bus interface clock, you can consider the related module register control clock.
   Internal clocks, you can consider it as the module clock, now take LPTMR as an example
You can find the LPTMR internal clocks is the module clock.
 I/o interface clock is the clock which is input or output to the related IO pins.
Wish it helps you!
Kerry
