Kinetis K22F PCB Requirements
1,631 次查看
eduardoumana
I am now moving towards designing a PCB using the MK22FN512VLH12 MCU and I can't seem to find in the data sheet or manual the requirements of the MCU to work standalone on the PCB. Where do I need external resistors, capacitors, crystals, etc... I am also planning to use SWD for programming, and I suspect I will need a pull-up resistor somewhere, but I can't find this information in the specs.
标记 (4)
1,471 次查看
Paul_Tian
Hi, Eduardo
I suggest you to have a look at a quick reference manual. In this manual, you can find its typical circuit and debug interface design.
http://cache.freescale.com/files/32bit/doc/quick_ref_guide/KQRUG.pdf.
Best Regards
Paul
