[KW36]How to use memory SRAM1/SRAM_L
772 次查看
ppx
I want to define uint8_t ucHeap[configTOTAL_HEAP_SIZE] in SRAM1 of kw36.
uint8_t ucHeap[configTOTAL_HEAP_SIZE] __attribute__((section(".data_RAM2")));
Please show me how to correctly define ucHeap into SRAM1. thank you.
751 次查看
ppx
The input name is used to define the variable!!!
Like this it will work properly:
uint8_t ucHeap[configTOTAL_HEAP_SIZE] __attribute__((section(".bss.$SRAM1")));
752 次查看
ppx
