KV58 CANBUS Communication
1,442 次查看
a8Chcx
Contributor V
I am using KV58  CANBUS to communicate the ESP32 CANBUS(Support ISO 11898-1).
1) When I try the communication between ESP32 board, it works fine.
2) When I try KV58 with K64F CANBUS, it works fine as well.
3) Then, I try KV58 CANBUS with ESP32, I cannot get it work. The difference between K64F CANBUS and ESP32 CANBUS is just MCU, all others(tranceiver, connection, and etc) are exactly same. I am wondering if it is related to timing settings?
Can anybody tell me how to fix this problem? Any suggestion?
Christie
1,423 次查看
_Leo_
Hi Christie,
Thank you so much for your interest in our products and for using our community.
I think you are correct. It is related to timing settings. If you are using the SDK examples of KV58 and K64, both bit rates are set to 1 Mb/s. Then it is only to check how the ESP32 is configured.
Hope it helps you. Please let me know if you have more questions about it.
Have a nice day!
