KV31 - FTDI chip with MPSSE interface as a generic JTAG programmer
shai_b
Senior Contributor II
Hello Team,
Could you please advise if it possible to use the FTDI chip for programming the KV31 MCU family using the JTAG interface over MPSSE?
The FTDI contains four channels and one of the interfaces is MPSSE which supports JTAG which It will be great if we can program the device via the FTDI.
Please refer to the FTDI datasheet: https://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT4232H.pdf
Waiting for your kind response, Thanks in advance.
Shai
Tags (3)
jingpan
Hi Shai,
We have no experience on this chip. You'd better consult to Future. I guess it is possible. KV31 JTAG port is a standard port.
Jing
shai_b
Dear Team,
There's any update?
Kind regards,
Shai
