KE18F512VLH16 ECC RAM Single Bit Correction
449件の閲覧回数
rseigle77
I have a follow up question related to @sean_dvorscak's post the other day (KE1 ECC RAM Single Bit Corrrection).
@Celeste_Liu replied,
->> If implementing an optional scrub, please align the access according to the actual access size or scrub granularity, not blindly to the raw MCM_LMFAR value. Also don't use a fixed 4-byte access unless you first align the address appropriately and confirm the access size is valid.
Can MCM_LMFATR[PEFSIZE] be used to determine the access size? If so, can this be used in tandem with MCM_LMFAR to implement a read-correct-writeback operation? For example, if MCM_LMFATR[PEFSIZE] is 3'b000 indicating an 8-bit access, can I perform an 8-bit read from the address indicated by MCM_LMFAR then perform an 8-bit write to the same address to correct the error. Similarly, if MCM_LMFATR[PEFSIZE] is 3'b010 indicating a 32-bit access, can I perform a 32-bit write to the address indicated by MCM_LMFAR without worrying about alignment?
6 返答(返信)
360件の閲覧回数
Celeste_Liu
Hello @rseigle77 ,
Regarding your question, I need to escalate it to our internal team for further investigation. According to our process, please provide the end application name.
Thanks for your cooperation.
Celeste
144件の閲覧回数
rseigle77
Hi @Celeste_Liu, is there any update on this?
41件の閲覧回数
Celeste_Liu
Hello @rseigle77 ,
Sorry, I still haven't received a response from the internal yet.
I'll follow up with them again and make this my top priority. As soon as I hear anything back, I'll let you know right away.
Celeste
4件の閲覧回数
Celeste_Liu
Hello @rseigle77 ,
Thanks for your patience. I got the reply from the internal.
ECC "correction" means returning corrected data to the CPU, not fixing the underlying bit stored in SRAM. Automatic repair requires a separate scrub/write-back mechanism.
The recommended flow to use software scrub:
  • ECC corrects data on read.
  • Single-bit error interrupt/status is raised. Refer to RM 6.3.1.1 Determining source of the interrupt. MCM_LMPECR[ER1BR]=1
  • Software reads the fault address. MCM_LMPEIR[PEELOC] = 5'h08 - a 1-bit correctable ECC event from SRAM_L, MCM_LMFAR indicates fault address.
  • Software rewrites the corrected value back to the same address.
  • New ECC syndrome is generated and stored.
Celeste
346件の閲覧回数
rseigle77
Hi @Celeste_Liu  - P7 is the name of the end application.
380件の閲覧回数
Celeste_Liu
Hello @rseigle77 ,
I have seen your post. Let me spend some time investigating this issue, and I will get back to you once I have more information.
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2404369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKE18F512VLH16%20ECC%20RAM%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%E8%A8%82%E6%AD%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%88%E6%97%A5%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90401%22%20target%3D%22_blank%22%3E%40sean_dvorscak%3C%2FA%3E%E3%81%95%E3%82%93%E3%81%8C%E6%8A%95%E7%A8%BF%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%98%E4%BA%8B%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FKinetis-Microcontrollers%2FKE1-ECC-RAM-Single-Bit-Corrrection%2Fm-p%2F2399360%23M68449%22%20target%3D%22_blank%22%3EKE1%20ECC%20RAM%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%E8%A8%82%E6%AD%A3%3C%2FA%3E%EF%BC%89%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%E3%81%AF%E7%AD%94%E3%81%88%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E-%26gt%3B%26gt%3B%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%96%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%84%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%96%E3%81%AE%E7%B2%92%E5%BA%A6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%80%81%E7%94%9F%E3%81%AE%20MCM_LMFAR%20%E5%80%A4%E3%81%AB%E7%9B%B2%E7%9B%AE%E7%9A%84%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E5%9B%BA%E5%AE%9A4%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AF%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMCM_LMFATR%5BPEFSIZE%5D%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%88%A4%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%81%93%E3%82%8C%E3%82%92MCM_LMFAR%E3%81%A8%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%BB%E6%AD%A3%E8%A7%A3%E3%83%BB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81MCM_LMFATR%5BPEFSIZE%5D%E3%81%8C3'b000%E3%81%A78%E3%83%93%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81MCM_LMFAR%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8B%E3%82%898%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%E5%90%8C%E3%81%98%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB8%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E3%81%97%E3%81%A6%E8%AA%A4%E3%82%8A%E3%82%92%E8%A8%82%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81MCM_LMFATR%5BPEFSIZE%5D%E3%81%8C3'b010%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%B0%97%E3%81%AB%E3%81%9B%E3%81%9A%E3%81%ABMCM_LMFAR%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB32%E3%83%93%E3%83%83%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237024%22%20target%3D%22_blank%22%3E%E3%80%81%40rseigle77%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E6%8B%9D%E8%A6%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%B0%91%E3%81%97%E8%AA%BF%E6%9F%BB%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E8%A9%B3%E3%81%97%E3%81%84%E6%83%85%E5%A0%B1%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E6%AC%A1%E7%AC%AC%E3%80%81%E6%94%B9%E3%82%81%E3%81%A6%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%20-%20P7%E3%81%AF%E6%9C%80%E7%B5%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237024%22%20target%3D%22_blank%22%3E%E3%80%81%40rseigle77%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%8D%E3%81%BE%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E7%A4%BE%E5%86%85%E3%81%AE%E6%8B%85%E5%BD%93%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E8%AA%BF%E6%9F%BB%E3%82%92%E4%BE%9D%E9%A0%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%BD%93%E7%A4%BE%E3%81%AE%E6%89%8B%E7%B6%9A%E3%81%8D%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%20%3CSTRONG%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E7%94%B3%E8%AB%8B%3C%2FSTRONG%3E%20%E5%90%8D%E3%82%92%E8%A8%98%E8%BC%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E9%80%B2%E5%B1%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237024%22%20target%3D%22_blank%22%3E%E3%80%81%40rseigle77%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E7%A4%BE%E5%86%85%E3%81%8B%E3%82%89%E3%81%AE%E8%BF%94%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%86%8D%E5%BA%A6%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E6%9C%80%E5%84%AA%E5%85%88%E4%BA%8B%E9%A0%85%E3%81%A8%E3%81%97%E3%81%A6%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E8%BF%94%E4%BA%8B%E3%81%8C%E6%9D%A5%E3%81%9F%E3%82%89%E3%81%99%E3%81%90%E3%81%AB%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%3C%2FLINGO-BODY%3E
