KE18F512VLH16 ECC RAM Single Bit Correction
442 次查看
rseigle77
I have a follow up question related to @sean_dvorscak's post the other day (KE1 ECC RAM Single Bit Corrrection).
@Celeste_Liu replied,
->> If implementing an optional scrub, please align the access according to the actual access size or scrub granularity, not blindly to the raw MCM_LMFAR value. Also don't use a fixed 4-byte access unless you first align the address appropriately and confirm the access size is valid.
Can MCM_LMFATR[PEFSIZE] be used to determine the access size? If so, can this be used in tandem with MCM_LMFAR to implement a read-correct-writeback operation? For example, if MCM_LMFATR[PEFSIZE] is 3'b000 indicating an 8-bit access, can I perform an 8-bit read from the address indicated by MCM_LMFAR then perform an 8-bit write to the same address to correct the error. Similarly, if MCM_LMFATR[PEFSIZE] is 3'b010 indicating a 32-bit access, can I perform a 32-bit write to the address indicated by MCM_LMFAR without worrying about alignment?
5 回复数
353 次查看
Celeste_Liu
Hello @rseigle77 ,
Regarding your question, I need to escalate it to our internal team for further investigation. According to our process, please provide the end application name.
Thanks for your cooperation.
Celeste
137 次查看
rseigle77
Hi @Celeste_Liu, is there any update on this?
34 次查看
Celeste_Liu
Hello @rseigle77 ,
Sorry, I still haven't received a response from the internal yet.
I'll follow up with them again and make this my top priority. As soon as I hear anything back, I'll let you know right away.
Celeste
339 次查看
rseigle77
Hi @Celeste_Liu  - P7 is the name of the end application.
373 次查看
Celeste_Liu
Hello @rseigle77 ,
I have seen your post. Let me spend some time investigating this issue, and I will get back to you once I have more information.
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2404369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKE18F512VLH16%20ECC%20RAM%20%E5%8D%95%E6%AF%94%E7%89%B9%E7%BA%A0%E9%94%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E4%B8%8E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90401%22%20target%3D%22_blank%22%3E%40sean_dvorscak%3C%2FA%3E%E5%89%8D%E5%87%A0%E5%A4%A9%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FKinetis-Microcontrollers%2FKE1-ECC-RAM-Single-Bit-Corrrection%2Fm-p%2F2399360%23M68449%22%20target%3D%22_blank%22%3EKE1%20ECC%20RAM%20%E5%8D%95%E6%AF%94%E7%89%B9%E7%BA%A0%E9%94%99%3C%2FA%3E%EF%BC%89%E7%9B%B8%E5%85%B3%E7%9A%84%E5%90%8E%E7%BB%AD%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%E5%9B%9E%E5%A4%8D%E9%81%93%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E8%A6%81%E5%AE%9E%E7%8E%B0%E5%8F%AF%E9%80%89%E7%9A%84%E6%B8%85%E7%90%86%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%AF%B7%E6%A0%B9%E6%8D%AE%E5%AE%9E%E9%99%85%E8%AE%BF%E9%97%AE%E5%A4%A7%E5%B0%8F%E6%88%96%E6%B8%85%E7%90%86%E7%B2%92%E5%BA%A6%E6%9D%A5%E5%AF%B9%E9%BD%90%E8%AE%BF%E9%97%AE%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%9B%B2%E7%9B%AE%E5%9C%B0%E4%BE%9D%E8%B5%96%E5%8E%9F%E5%A7%8B%E7%9A%84%20MCM_LMFAR%20%E5%80%BC%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E9%99%A4%E9%9D%9E%E6%82%A8%E5%B7%B2%E6%AD%A3%E7%A1%AE%E5%AF%B9%E9%BD%90%E5%9C%B0%E5%9D%80%E5%B9%B6%E7%A1%AE%E8%AE%A4%E8%AE%BF%E9%97%AE%E5%A4%A7%E5%B0%8F%E6%9C%89%E6%95%88%EF%BC%8C%E5%90%A6%E5%88%99%E8%AF%B7%E5%8B%BF%E4%BD%BF%E7%94%A8%E5%9B%BA%E5%AE%9A%E7%9A%84%204%20%E5%AD%97%E8%8A%82%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMCM_LMFATR%5BPEFSIZE%5D%20%E8%83%BD%E5%90%A6%E7%94%A8%E4%BA%8E%E7%A1%AE%E5%AE%9A%E8%AE%BF%E9%97%AE%E5%A4%A7%E5%B0%8F%EF%BC%9F%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%EF%BC%8C%E8%83%BD%E5%90%A6%E5%B0%86%E5%85%B6%E4%B8%8E%20MCM_LMFAR%20%E7%BB%93%E5%90%88%E4%BD%BF%E7%94%A8%EF%BC%8C%E4%BB%A5%E5%AE%9E%E7%8E%B0%E8%AF%BB%E5%8F%96-%E6%AD%A3%E7%A1%AE-%E5%86%99%E5%9B%9E%E6%93%8D%E4%BD%9C%EF%BC%9F%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%A6%82%E6%9E%9C%20MCM_LMFATR%5BPEFSIZE%5D%20%E4%B8%BA%203'b000%EF%BC%8C%E8%A1%A8%E7%A4%BA%208%20%E4%BD%8D%E8%AE%BF%E9%97%AE%EF%BC%8C%E6%88%91%E8%83%BD%E5%90%A6%E4%BB%8E%20MCM_LMFAR%20%E6%8C%87%E7%A4%BA%E7%9A%84%E5%9C%B0%E5%9D%80%E6%89%A7%E8%A1%8C%208%20%E4%BD%8D%E8%AF%BB%E5%8F%96%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AF%B9%E5%90%8C%E4%B8%80%E5%9C%B0%E5%9D%80%E6%89%A7%E8%A1%8C%208%20%E4%BD%8D%E5%86%99%E5%85%A5%E4%BB%A5%E7%BA%A0%E6%AD%A3%E9%94%99%E8%AF%AF%EF%BC%9F%E5%90%8C%E6%A0%B7%E5%9C%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%20MCM_LMFATR%5BPEFSIZE%5D%20%E4%B8%BA%203'b010%EF%BC%8C%E8%A1%A8%E7%A4%BA%2032%20%E4%BD%8D%E8%AE%BF%E9%97%AE%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%AF%B9%20MCM_LMFAR%20%E6%8C%87%E7%A4%BA%E7%9A%84%E5%9C%B0%E5%9D%80%E6%89%A7%E8%A1%8C%2032%20%E4%BD%8D%E5%86%99%E5%85%A5%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E6%8B%85%E5%BF%83%E5%AF%B9%E9%BD%90%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237024%22%20target%3D%22_blank%22%3E%40rseigle77%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%9C%8B%E8%BF%87%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4%E6%9D%A5%E8%B0%83%E6%9F%A5%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B8%80%E6%97%A6%E6%9C%89%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%BD%E5%BF%AB%E5%9B%9E%E5%A4%8D%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%A1%9E%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%20-%20P7%20%E6%98%AF%E6%9C%80%E7%BB%88%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237024%22%20target%3D%22_blank%22%3E%40rseigle77%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%E5%85%B6%E4%B8%8A%E6%8A%A5%E7%BB%99%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E6%9F%A5%E3%80%82%E6%A0%B9%E6%8D%AE%E6%88%91%E4%BB%AC%E7%9A%84%E6%B5%81%E7%A8%8B%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BE%9B%3CSTRONG%3E%E6%9C%80%E7%BB%88%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%90%88%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%A1%9E%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%AF%B7%E9%97%AE%E8%BF%99%E4%BB%B6%E4%BA%8B%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KE18F512VLH16%20ECC%20RAM%20Single%20Bit%20Correction%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237024%22%20target%3D%22_blank%22%3E%40rseigle77%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E5%86%85%E9%83%A8%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%86%8D%E6%AC%A1%E8%B7%9F%E8%BF%9B%E6%AD%A4%E4%BA%8B%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E4%BD%9C%E4%B8%BA%E6%88%91%E7%9A%84%E9%A6%96%E8%A6%81%E4%BB%BB%E5%8A%A1%E3%80%82%E4%B8%80%E6%97%A6%E6%94%B6%E5%88%B0%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BC%9A%E7%AB%8B%E5%8D%B3%E9%80%9A%E7%9F%A5%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%A1%9E%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
