KDS debugger with DAPLink
1,944件の閲覧回数
roymessinger
I've just updated the bootloader and firmware to DAPLink (OpenSDA Serial and Debug Adapter|NXP )
How do I use the KDS debugger, when I connect the microUSB to the FRDM K64 board?
I don't see any OpenSDA in the KDS:
3 返答(返信)
1,662件の閲覧回数
Robin_Shen
Hi roymessinger,
Please refer this "KDS Debug Configurations (OpenOCD, P&E, Segger)".
If you want to use OpenSDA, please select GDB PEMicro Interface Debugging.
Robin
1,662件の閲覧回数
roymessinger
Thanks, but not working. FRDM k64 is connected via USB (to host):
And I'm getting this error message:
1,662件の閲覧回数
Robin_Shen
I can see the OpenSDA port in PEMicro Interface Settings and Device Manager.
Have you try to use other firmware application?
See also the Note if you are using Windows 10.
Robin
