K70 processor reset pin always low
2,384件の閲覧回数
felicita
Fresh Out Contributor
Hi all,
The reset pin is always low in our custom K70 board. We have pulled the reset pin up externally using 10k resistor. EzPort pin is also pulled high through 10k resistor. We aren't able to trace why this persists.
Your inputs would help us a lot!
Thank You!
Felicita.
3 返答(返信)
2,142件の閲覧回数
EarlOrlando
Senior Contributor II
Hello Felicita,
Could you please share with us the debug/programming interface section of your schematic?
Earl.
2,142件の閲覧回数
felicita
Hi Earl,
Following is the debug interface of our board:
Felicita.
2,142件の閲覧回数
pramodkc
Hi Felicita,
     Did you figure out what is happening ? We have the same problem with a custom board with an MKW24.
Pramod
