It seems that we can find the SWD-DP interface which puts us on step 6. However, the script outputed from the reset pin script is the following:
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link V10 compiled Jan 7 2020 16:51:47
Hardware version: V10.10
S/N: 50114001
License(s): GDB
VTref=3.303V
Selecting 1000 kHz as target interface speed
Sleep(10)
Target connection not established yet but required for command.
Please specify device / core. <Default>: MK66FN2M0XXX18
Type '?' for selection dialog
Device>
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Device "MK66FN2M0XXX18" selected.
Connecting to target via JTAG
InitTarget()
Protection bytes in flash at addr. 0x400 - 0x40F indicate that readout protection is set.
For debugger connection the device needs to be unsecured.
Note: Unsecuring will trigger a mass erase of the internal flash.
Executing default behavior previously saved in the registry.
Device will be unsecured now.
Timeout while halting CPU.
TotalIRLen = 4, IRPrint = 0x01
JTAG chain detection found 1 devices:
#0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x001C0000)
Iterating through AP map to find AHB-AP to use
AP[0]: Skipped. Invalid implementer code read from CPUIDVal[31:24] = 0x00
AP[1]: Skipped. Not an AHB-AP
InitTarget()
****** Error: Could not find core in Coresight setup
InitTarget()
InitTarget()
Cannot connect to target.
InitTarget()
InitTarget()
InitTarget()
InitTarget()
InitTarget()
InitTarget()
InitTarget()
InitTarget()
Readout protection is set and mass erase is disabled. J-Link cannot unprotect the device.
Sleep(1000)
Selecting SWD as current target interface.
Sleep(10)
Select SWD by sending SWD switching sequence.
Found SWD-DP with ID 0x2BA01477
Sleep(10)
Write DP register 2 = 0x01000000
Sleep(10)
Read AP register 0 = 0x00000000
Sleep(10)
Read AP register 0 = 0x00000037
Sleep(10)
Read AP register 1 = 0x00000037
Sleep(10)
Read AP register 1 = 0x00000000
Sleep(10)
Sleep(10)
Sleep(10)
Write AP register 1 = 0x00000001
Sleep(1000)
Sleep(10)
Sleep(10)
Sleep(10)
Read AP register 1 = 0x00000001
Sleep(100)
Write DP register 2 = 0x00000000
Sleep(1000)
Selecting JTAG as current target interface.
Sleep(100)
InitTarget()
InitTarget()
InitTarget()
InitTarget()
Script processing completed.
