K66 interrupt controller register
2,093 次查看
arielablumer
This is kind of a veru basic question but I couldn't find in the K66 Sub-Family Reference Manual the interrupt controller register. Specifically I'd like to know which register is used for enabling/disabling all interrupts (the one affected by CPSIE/D I). Is this register visible in the debugger?
Ariela
1,815 次查看
kerryzhou
Hi Ariela,
    K66 is the ARM cortex -M4 core, about the interrupt register, you can find it in the ARM cortex M4 core document, please go to this link:
ARM Information Center
    CPSIE I    Enable interrupts (clear PRIMASK). Same as __enable_irq();
    CPSID I  Disable interrupts (set PRIMASK). NMI and HardFault are not affected. Same as __disable_irq();
Wish it helps you!
If you still have question, please contact me!
Jingjing
1,815 次查看
egoodii
Senior Contributor III
See the 'basic' answers in:
How does “CPSID” (used to control interrupts) work?
Will the KL17 allow higher priority interrupts to interrupt a lower priority interrupt?
Register window (including PRIMASK) in IAR on an M0+ core (no BASEPRI as K66 will have):
