K64F only enter Bootloader
5,000 次查看
chenlucas
Hello everyone,
I have a question about FRDM K64F board.
Today, I used K64F plugin computer
But K64F OpenSDA Green LED isn`t bright work, if i press reset switch.
My computer will get K64F enter bootloader mode.(Green LED will blink)
My computer OS is windows 10, and I updated below firmware version.
OpenSDA version / bootloader
标记 (1)
5 回复数
3,549 次查看
Hello Chen,
- There are three debug inter faces we can choose for OpenSDA: Segger J-Link OpenSDA, P&E OpenSDA interface, or Mbed interface.
Please  Drag'n drop or copy and paste the corresponding  OpenSDA Application binary file into the BOOTLOADER drive from your computer file explorer.
About the detail steps please refer to :
OpenSDA Serial and Debug Adapter|NXP
- Also there is a  summary for debug interface, it is for FRDM-K22, while it is the same with FRDM-K64 .
Summary of FRDM-K22F debug interface
Hope it helps!
TIC
3,549 次查看
chenlucas
Hi Alice_Yang,
Thank you,
I have follow the step update firmware K64F will reset.
But always enter bootloader.
I do not use K64F a period of time.
Final, K64F can normal work.
I don`t know the issue source.
but I have twice experience, I want to know the source.
I want to avoid the issue.
3,549 次查看
Hello Chen,
How about on Win7 ?
And could you please take a video or screenshots about your steps .
Alice
3,549 次查看
chenlucas
Hi Alice ,
My computer used win 10 OS.
Now, My K64F can get normal mode.
 My step is ...
step 1) Download SDA firmware
step 2) Hold the reset sw
step 3) next plugin usb cable in computer
step 4) disk appear bootloader disk in my computer
step 5) moving *.bin file to bootloader disk
Final K64F reset
But firmware don`t update.
Thank Alice!
3,549 次查看
1. I recommend you use another PC (it's better Win7) to check whether your board work well,
check the problem is your board or PC.
2. step 5) moving *.bin file to bootloader disk , please send this .bin file to me , I test it on my board.
ALice
