K64F instruction cache operation
1,542 次查看
adriangogu
I am using FRDM-K64F module.
Found in ARM documentation a note telling: "A small caching component is present in the Cortex-M3 and Cortex-M4 processors to accelerate flash memory accesses during instruction fetches."
Referring to this note I would ask whether such instruction cache component is implemented within K64 microcontroller.
Could you please indicate documentation describing the operation / configuration of the mentioned instruction cache ?
For application code profiling accuracy, I would be interested to know if instruction cache usage can be disabled/bypassed ?
Thank you.
Adrian
标签 (1)
标记 (1)
1 回复
1,412 次查看
adriangogu
Found instruction cache described in K64 Sub-Family Reference Manual, chapter 28, Flash Memory Controller (FMC).
