I would like to update my firmware remotely by pushing my microcontroller (MK64FN1M0VLQ12) in bootloader mode and send the new application via UART.
How do I enter in the bootloader mode through my application in order to send the new firmware by the UART.
I try this,
#define BL_VECTORS 0x0
uint32_t run_bootloader;
* Step: Disable systick timer and reset it to default values
SysTick->CTRL = 0;
SysTick->LOAD = 0;
SysTick->VAL = 0;
* Step: Disable all interrupts
__disable_irq();
* Jump to boot_loader
run_bootloader = ((uint32_t*)BL_VECTORS)[1];
((void(*)(void))run_bootloader)();
My application make a reset and restart my application.
Thank you in advance.
Julien
