I'm try to usage gpio PTE9 as open drain output on K60DN, but looks like it's still push-pull.
Init code:
CLOCK_EnableClock(kCLOCK_PortE);
GPIOE->PCOR = 1U << 9;
GPIOE->PDDR |= (1U << 9);
PORTE->PCR[9] = PORT_PCR_ODE(1) | PORT_PCR_MUX(1);
GPIOE->PSOR = 1U << 9;
After last line i expect zero voltage on this pin (couse it's connect to ground) - but i'm still have 3V on this pin. This pin don't have any external pull-up.
If i clear output register:
voltage level on this pin drops to zero.
I expect to have GND on this pint in case setted output register and float pin on cleared register. Is any way to solve this situation?
