Programacion K40x256 Cortex M-4
sebastian_ernes
Hola, necesito informacion para aprender a programar un kit de desarrollo TWR-K40x256 ARM Cortex M-4 en codewarrior, podrian recomendarme algun manual de programacion o algun material similar ?
kerryzhou
Hi Sebastian Gonzalez ,
   Next time, please create your question in English.
   This time, I use the translation tool to translate your question:
Hello, I need information to learn how to program a development kit TWR-K40x256 ARM Cortex M-4 in codewarrior, could you recommend me some programming manual or some similar material?
  Answer your question:
 Actually, TWR-K40x256 is really a little old now.
  But if you want to use it,  you can refer to the document in this link:
TWR-K40X256|Tower System Board|Kinetis MCUs | NXP
  About the code, I attach the KINETIS512_SC.zip, it already have the CW project for your board.
 The board already have the on board debugger, you can use it directly.
Wish it helps you!
Kerry
