K21 Tower Kit not booting
3,253件の閲覧回数
abbian
Hi All -
I am developing a K21 application.  My code will run fine if I download and debug from within the IAR debugger, but it will not boot on it's own.
Any ideas?
3,127件の閲覧回数
abbian
Hey Kan
I found the problem - the watchdog was not being disabled at startup.
Dan
4 返答(返信)
3,127件の閲覧回数
Kan_Li
Hi Dan,
Would you please specify the tower board version? Is it the TWR-K21F120M? and it would be better that you could send your code for a review.
Thanks for your patience!
B.R
Kan
3,127件の閲覧回数
abbian
Hi Kan -
I'm using the TWR-K21F120M.  My code is based on the gpio example in the tower sample code.  If I specify the 512KPflash linker file in the gpio project and download it using the Jlink the board will boot into the gpio code.  When I do the same with my code it hangs unless I start it in the debugger.
What is the best way to send you my code?
Dan
3,127件の閲覧回数
Kan_Li
Hi Dan,
That looks like a software issue, so you may attach your project here, and I will try to reproduce this issue with my TWR-K21F120M. Thanks for your patience!
B.R
Kan
3,127件の閲覧回数
abbian
Hey Kan
Dan
