K20 programming & reset w Cyclone
1,013 次查看
darkohadzidedic
We use Cyclone ARM and MAX for Kinetis K20, 120MHz. After the part is programmed, the reset is released by Cyclone, but micro does not come up. I can remove programmer from JTAG and manually reset part;
still down. Only after the power cycle, the micro comes up. Once the micro is running, reset works fine.
Any idea what is going on?
0 回复数
