K20 programming & reset w Cyclone
1,036件の閲覧回数
darkohadzidedic
We use Cyclone ARM and MAX for Kinetis K20, 120MHz. After the part is programmed, the reset is released by Cyclone, but micro does not come up. I can remove programmer from JTAG and manually reset part;
still down. Only after the power cycle, the micro comes up. Once the micro is running, reset works fine.
Any idea what is going on?
0 返答(返信)
