Is there any ARM development board from Freescale with Analog camera interface (NTSC or PAL) supported
2,931 次查看
admin
Specialist II
Hi can you please help me answer this request,
I need an ARM development board from Freescale with Analog camera interface (NTSC or PAL) supported.
Thanks in Advance!!!
Denisse
4 回复数
2,106 次查看
admin
Specialist II
Thank you :smileyhappy:
2,106 次查看
LuisCasado
Vybrid processors has video input, upto 4 channels. VF6xx derivative. But TWR system doesn't implement the video input. You can find many Vybrid modules in the market, but no video input easy to get in the carrier board. BUT, you can check this solution:
http://devicesolutions.net/vybrid.aspx
That board implements 2 x RCA Video input in the development kit.
Luis
2,106 次查看
terrypeterson-b
This board isn’t made by Freescale, but it uses an i.MX233 iMX233 ARM926J processor at 454Mhz and has an NTSC/PAL interface:
https://www.olimex.com/Products/OLinuXino/iMX233/iMX233-OLinuXino-MINI/open-source-hardware
2,106 次查看
LuisCasado
Hi Terry,
i.MX233 has analog video output
Luis
