Is there any ARM development board from Freescale with Analog camera interface (NTSC or PAL) supported
admin
Specialist II
Hi can you please help me answer this request,
I need an ARM development board from Freescale with Analog camera interface (NTSC or PAL) supported.
Thanks in Advance!!!
Denisse
admin
Specialist II
Thank you :smileyhappy:
LuisCasado
Vybrid processors has video input, upto 4 channels. VF6xx derivative. But TWR system doesn't implement the video input. You can find many Vybrid modules in the market, but no video input easy to get in the carrier board. BUT, you can check this solution:
http://devicesolutions.net/vybrid.aspx
That board implements 2 x RCA Video input in the development kit.
Luis
terrypeterson-b
This board isn’t made by Freescale, but it uses an i.MX233 iMX233 ARM926J processor at 454Mhz and has an NTSC/PAL interface:
https://www.olimex.com/Products/OLinuXino/iMX233/iMX233-OLinuXino-MINI/open-source-hardware
LuisCasado
Hi Terry,
i.MX233 has analog video output
Luis
