Is there any ARM development board from Freescale with Analog camera interface (NTSC or PAL) supported
2,927件の閲覧回数
admin
Specialist II
Hi can you please help me answer this request,
I need an ARM development board from Freescale with Analog camera interface (NTSC or PAL) supported.
Thanks in Advance!!!
Denisse
4 返答(返信)
2,102件の閲覧回数
admin
Specialist II
Thank you :smileyhappy:
2,102件の閲覧回数
LuisCasado
Vybrid processors has video input, upto 4 channels. VF6xx derivative. But TWR system doesn't implement the video input. You can find many Vybrid modules in the market, but no video input easy to get in the carrier board. BUT, you can check this solution:
http://devicesolutions.net/vybrid.aspx
That board implements 2 x RCA Video input in the development kit.
Luis
2,102件の閲覧回数
terrypeterson-b
This board isn’t made by Freescale, but it uses an i.MX233 iMX233 ARM926J processor at 454Mhz and has an NTSC/PAL interface:
https://www.olimex.com/Products/OLinuXino/iMX233/iMX233-OLinuXino-MINI/open-source-hardware
2,102件の閲覧回数
LuisCasado
Hi Terry,
i.MX233 has analog video output
Luis
