Is there a header file BME.h
已解决
跳至解决方案
4,750 次查看
jun1
Contributor V
Hi.
I am using KM34.
Is there a header file when using the Bit Manipulation Engine (BME)?
#define BME_AND (ADDR) ????
1 解答
4,720 次查看
bobpaddock
Senior Contributor III
I attached what you are looking for.
What I'd like to know is where to find?:
"Bit Manipulation engine Block Guide v0.3."
that that file was created from.
The KE04 driver library has a BME demo with code:
https://community.nxp.com/t5/Kinetis-Microcontrollers/BME-h/m-p/945486
I never understand why NXP makes this stuff so hard to find...
在原帖中查看解决方案
3 回复数
4,721 次查看
bobpaddock
4,736 次查看
nxf77486
Hello @jun1 ,
Can you please help me by providing more information regarding your request.
Are you using and SDK example for the KM34?
TWR-KM34Z75M
4,726 次查看
jun1
Contributor V
Hi.
thank you for your reply.
SDK uses "SDK_2_10_0_MKM34Z256xxx7". Attach the content list.
So, is there an API to access BME to the drivers in this?
I don't think fsl_gpio.c is using BME, but if you are using BME, please tell me what kind of API it will be.
Thank you.
